MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
action=setpagelanguage
(main | setpagelanguage)
  • Voor deze module zijn leesrechten nodig.
  • Voor deze module zijn schrijfrechten nodig.
  • This module only accepts POST requests.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Wijzig de taal van een pagina.
Changing the language of a page is not allowed on this wiki.
Enable $wgPageLanguageUseDB to use this action.
Parameters:
title
Title of the page whose language you wish to change. Cannot be used together with pageid.
pageid
Page ID of the page whose language you wish to change. Cannot be used together with title.
Type: geheel getal
lang
Language code of the language to change the page to. Use default to reset the page to the wiki's default content language.
Deze parameter is verplicht.
Een van de volgende waarden: default, ab, abs, ace, ady, ady-cyrl, aeb, aeb-arab, aeb-latn, af, ak, aln, als, am, an, ang, anp, ar, arc, arn, arq, ary, arz, as, ase, ast, atj, av, avk, awa, ay, az, azb, ba, ban, bar, bat-smg, bbc, bbc-latn, bcc, bcl, be, be-tarask, be-x-old, bg, bgn, bh, bho, bi, bjn, bm, bn, bo, bpy, bqi, br, brh, bs, btm, bto, bug, bxr, ca, cbk-zam, cdo, ce, ceb, ch, chr, chy, ckb, co, cps, cr, crh, crh-cyrl, crh-latn, cs, csb, cu, cv, cy, da, de, de-at, de-ch, de-formal, din, diq, dsb, dtp, dty, dv, dz, ee, egl, el, eml, en, en-ca, en-gb, eo, es, es-formal, et, eu, ext, fa, ff, fi, fit, fiu-vro, fj, fo, fr, frc, frp, frr, fur, fy, ga, gag, gan, gan-hans, gan-hant, gcr, gd, gl, glk, gn, gom, gom-deva, gom-latn, gor, got, grc, gsw, gu, gv, ha, hak, haw, he, hi, hif, hif-latn, hil, hr, hrx, hsb, ht, hu, hu-formal, hy, hyw, ia, id, ie, ig, ii, ik, ike-cans, ike-latn, ilo, inh, io, is, it, iu, ja, jam, jbo, jut, jv, ka, kaa, kab, kbd, kbd-cyrl, kbp, kg, khw, ki, kiu, kjp, kk, kk-arab, kk-cn, kk-cyrl, kk-kz, kk-latn, kk-tr, kl, km, kn, ko, ko-kp, koi, krc, kri, krj, krl, ks, ks-arab, ks-deva, ksh, ku, ku-arab, ku-latn, kum, kv, kw, ky, la, lad, lb, lbe, lez, lfn, lg, li, lij, liv, lki, lmo, ln, lo, loz, lrc, lt, ltg, lus, luz, lv, lzh, lzz, mai, map-bms, mdf, mg, mhr, mi, min, mk, ml, mn, mni, mnw, mo, mr, mrj, ms, mt, mwl, my, myv, mzn, na, nah, nan, nap, nb, nds, nds-nl, ne, new, niu, nl, nl-informal, nn, no, nov, nrm, nso, nv, ny, nys, oc, olo, om, or, os, pa, pag, pam, pap, pcd, pdc, pdt, pfl, pi, pih, pl, pms, pnb, pnt, prg, ps, pt, pt-br, qu, qug, rgn, rif, rm, rmy, ro, roa-rup, roa-tara, ru, rue, rup, ruq, ruq-cyrl, ruq-latn, rw, sa, sah, sat, sc, scn, sco, sd, sdc, sdh, se, sei, ses, sg, sgs, sh, shi, shn, shy-latn, si, simple, sk, skr, skr-arab, sl, sli, sm, sma, sn, so, sq, sr, sr-ec, sr-el, srn, ss, st, stq, sty, su, sv, sw, szl, ta, tay, tcy, te, tet, tg, tg-cyrl, tg-latn, th, ti, tk, tl, tly, tn, to, tpi, tr, tru, ts, tt, tt-cyrl, tt-latn, tw, ty, tyv, tzm, udm, ug, ug-arab, ug-latn, uk, ur, uz, ve, vec, vep, vi, vls, vmf, vo, vot, vro, wa, war, wo, wuu, xal, xh, xmf, xsy, yi, yo, yue, za, zea, zgh, zh, zh-classical, zh-cn, zh-hans, zh-hant, zh-hk, zh-min-nan, zh-mo, zh-my, zh-sg, zh-tw, zh-yue, zu
reason
Reason for the change.
tags
Change tags to apply to the log entry resulting from this action.
Waarden (gescheiden met | of alternatief):
token
A "csrf" token retrieved from action=query&meta=tokens
Voorbeelden:
Change the language of Main Page to Basque.
api.php?action=setpagelanguage&title=Main%20Page&lang=eu&token=123ABC [open in de zandbak]
Change the language of the page with ID 123 to the wiki's default content language.
api.php?action=setpagelanguage&pageid=123&lang=default&token=123ABC [open in de zandbak]
