MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
action=userrights
(main | userrights)
  • Voor deze module zijn leesrechten nodig.
  • Voor deze module zijn schrijfrechten nodig.
  • This module only accepts POST requests.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Change a user's group membership.
Parameters:
user
Gebruikersnaam.
Type: gebruikersnaam
userid
Gebruikers-ID.
Type: geheel getal
add
Add the user to these groups, or if they are already a member, update the expiry of their membership in that group.
Waarden (gescheiden met | of alternatief): bot, sysop, interface-admin, bureaucrat, confirmed
expiry
Expiry timestamps. May be relative (e.g. 5 months or 2 weeks) or absolute (e.g. 2014-09-18T12:34:56Z). If only one timestamp is set, it will be used for all groups passed to the add parameter. Use infinite, indefinite, infinity, or never for a never-expiring user group.
Separate values with | or alternative. Het maximaal aantal waarden is 50 (500 voor bots).
Standaard: infinite
remove
Verwijder de gebruiker uit deze groepen.
reason
Reden voor de wijziging.
Default: (empty)
token
A "userrights" token retrieved from action=query&meta=tokens
For compatibility, the token used in the web UI is also accepted.
Deze parameter is verplicht.
tags
Change tags to apply to the entry in the user rights log.
Voorbeelden:
Add user FooBot to group bot, and remove from groups sysop and bureaucrat.
api.php?action=userrights&user=FooBot&add=bot&remove=sysop|bureaucrat&token=123ABC [open in de zandbak]
Add the user with ID 123 to group bot, and remove from groups sysop and bureaucrat.
api.php?action=userrights&userid=123&add=bot&remove=sysop|bureaucrat&token=123ABC [open in de zandbak]
Add user SometimeSysop to group sysop for 1 month.
api.php?action=userrights&user=SometimeSysop&add=sysop&expiry=1%20month&token=123ABC [open in de zandbak]
