MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=usercontribs (uc)
(main | query | usercontribs)
  • Voor deze module zijn leesrechten nodig.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Alle bewerkingen door een gebruiker opvragen.
Parameters:
uclimit
Het maximale aantal te tonen bijdragen.
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
Standaard: 10
ucstart
The start timestamp to return from.
Type: timestamp (allowed formats)
ucend
The end timestamp to return to.
uccontinue
When more results are available, use this to continue.
ucuser
The users to retrieve contributions for. Cannot be used with ucuserids or ucuserprefix.
Type: lijst met gebruikersnamen
Separate values with | or alternative. Het maximaal aantal waarden is 50 (500 voor bots).
ucuserids
The user IDs to retrieve contributions for. Cannot be used with ucuser or ucuserprefix.
Type: lijst met gehele getallen
ucuserprefix
Retrieve contributions for all users whose names begin with this value. Cannot be used with ucuser or ucuserids.
ucdir
In which direction to enumerate:
newer
List oldest first. Note: ucstart has to be before ucend.
older
List newest first (default). Note: ucstart has to be later than ucend.
Een van de volgende waarden: newer, older
Standaard: older
ucnamespace
Alleen bijdragen in deze naamruimten weergeven.
Waarden (gescheiden met | of alternatief): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
Gebruik * om alle waarden op te geven.
ucprop
Include additional pieces of information:
ids
Adds the page ID and revision ID.
title
Adds the title and namespace ID of the page.
timestamp
Adds the timestamp of the edit.
comment
Adds the comment of the edit.
parsedcomment
Adds the parsed comment of the edit.
size
Adds the new size of the edit.
sizediff
Adds the size delta of the edit against its parent.
flags
Adds flags of the edit.
patrolled
Tags patrolled edits.
tags
Lists tags for the edit.
Waarden (gescheiden met | of alternatief): ids, title, timestamp, comment, parsedcomment, size, sizediff, flags, patrolled, tags
Standaard: ids|title|timestamp|comment|size|flags
ucshow
Show only items that meet these criteria, e.g. non minor edits only: ucshow=!minor.
If ucshow=patrolled or ucshow=!patrolled is set, revisions older than $wgRCMaxAge (7776000 seconds) won't be shown.
Waarden (gescheiden met | of alternatief): minor, !minor, patrolled, !patrolled, autopatrolled, !autopatrolled, top, !top, new, !new
uctag
Alleen revisies met dit label weergeven.
uctoponly
Verouderd.
Only list changes which are the latest revision.
Type: boolean (details)
Voorbeelden:
Show contributions of user Example.
api.php?action=query&list=usercontribs&ucuser=Example [open in de zandbak]
Bijdragen van alle IP-adressen met het voorvoegsel 192.0.2. weergeven.
api.php?action=query&list=usercontribs&ucuserprefix=192.0.2. [open in de zandbak]
