MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
prop=stashimageinfo (sii)
(main | query | stashimageinfo)
  • Voor deze module zijn leesrechten nodig.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Returns file information for stashed files.
Parameters:
siifilekey
Key that identifies a previous upload that was stashed temporarily.
Separate values with | or alternative. Het maximaal aantal waarden is 50 (500 voor bots).
siisessionkey
Verouderd.
Alias for siifilekey, for backward compatibility.
siiprop
Which file information to get:
timestamp
Adds timestamp for the uploaded version.
canonicaltitle
Adds the canonical title of the file.
url
Gives URL to the file and the description page.
size
Adds the size of the file in bytes and the height, width and page count (if applicable).
dimensions
Alias for size.
sha1
Adds SHA-1 hash for the file.
mime
Adds MIME type of the file.
thumbmime
Adds MIME type of the image thumbnail (requires url and param siiurlwidth).
metadata
Lists Exif metadata for the version of the file.
commonmetadata
Lists file format generic metadata for the version of the file.
extmetadata
Lists formatted metadata combined from multiple sources. Results are HTML formatted.
bitdepth
Adds the bit depth of the version.
badfile
Adds whether the file is on the MediaWiki:Bad image list
Waarden (gescheiden met | of alternatief): timestamp, canonicaltitle, url, size, dimensions, sha1, mime, thumbmime, metadata, commonmetadata, extmetadata, bitdepth, badfile
Standaard: timestamp|url
siiurlwidth
If siiprop=url is set, a URL to an image scaled to this width will be returned. For performance reasons if this option is used, no more than 50 scaled images will be returned.
Type: geheel getal
Standaard: -1
siiurlheight
Similar to siiurlwidth.
Type: geheel getal
Standaard: -1
siiurlparam
A handler specific parameter string. For example, PDFs might use page15-100px. siiurlwidth must be used and be consistent with siiurlparam.
Default: (empty)
