MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=search (sr)
(main | query | search)
  • Voor deze module zijn leesrechten nodig.
  • This module can be used as a generator.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Voer een zoekopdracht in de volledige tekst uit.
Parameters:
srsearch
Search for page titles or content matching this value. You can use the search string to invoke special search features, depending on what the wiki's search backend implements.
Deze parameter is verplicht.
srnamespace
Search only within these namespaces.
Waarden (gescheiden met | of alternatief): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
Gebruik * om alle waarden op te geven.
Standaard: 0
srlimit
Hoeveel pagina's te tonen.
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
Standaard: 10
sroffset
When more results are available, use this to continue.
Type: geheel getal
Standaard: 0
srwhat
Which type of search to perform.
Een van de volgende waarden: title, text, nearmatch
srinfo
Which metadata to return.
Waarden (gescheiden met | of alternatief): totalhits, suggestion, rewrittenquery
Standaard: totalhits|suggestion|rewrittenquery
srprop
Which properties to return:
size
Adds the size of the page in bytes.
wordcount
Adds the word count of the page.
timestamp
Adds the timestamp of when the page was last edited.
snippet
Adds a parsed snippet of the page.
titlesnippet
Adds a parsed snippet of the page title.
redirecttitle
Adds the title of the matching redirect.
redirectsnippet
Adds a parsed snippet of the redirect title.
sectiontitle
Adds the title of the matching section.
sectionsnippet
Adds a parsed snippet of the matching section title.
isfilematch
Adds a boolean indicating if the search matched file content.
categorysnippet
Adds a parsed snippet of the matching category.
score
Verouderd. Genegeerd.
hasrelated
extensiondata
Adds extra data generated by extensions.
Waarden (gescheiden met | of alternatief): size, wordcount, timestamp, snippet, titlesnippet, redirecttitle, redirectsnippet, sectiontitle, sectionsnippet, isfilematch, categorysnippet, score, hasrelated, extensiondata
Standaard: size|wordcount|timestamp|snippet
srinterwiki
Include interwiki results in the search, if available.
Type: boolean (details)
srenablerewrites
Enable internal query rewriting. Some search backends can rewrite the query into another which is thought to provide better results, for instance by correcting spelling errors.
srsort
Set the sort order of returned results.
Een van de volgende waarden: relevance
Standaard: relevance
