MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
prop=revisions (rv)
(main | query | revisions)
  • Voor deze module zijn leesrechten nodig.
  • This module can be used as a generator.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Get revision information.
May be used in several ways:
  1. Get data about a set of pages (last revision), by setting titles or pageids.
  2. Get revisions for one given page, by using titles or pageids with start, end, or limit.
  3. Get data about a set of revisions by setting their IDs with revids.
Parameters:
rvprop
Which properties to get for each revision:
ids
The ID of the revision.
flags
Revision flags (minor).
timestamp
The timestamp of the revision.
user
User that made the revision.
userid
User ID of the revision creator.
size
Length (bytes) of the revision.
slotsize
Length (bytes) of each revision slot.
sha1
SHA-1 (base 16) of the revision.
slotsha1
SHA-1 (base 16) of each revision slot.
contentmodel
Content model ID of each revision slot.
comment
Comment by the user for the revision.
parsedcomment
Parsed comment by the user for the revision.
content
Tekst van de revisie.
tags
Labels voor de versie.
roles
List content slot roles that exist in the revision.
parsetree
Verouderd. Use action=expandtemplates or action=parse instead. The XML parse tree of revision content (requires content model wikitext).
Waarden (gescheiden met | of alternatief): ids, flags, timestamp, user, userid, size, slotsize, sha1, slotsha1, contentmodel, comment, parsedcomment, content, tags, roles, parsetree
Standaard: ids|timestamp|flags|comment|user
rvslots
Which revision slots to return data for, when slot-related properties are included in rvprops. If omitted, data from the main slot will be returned in a backwards-compatible format.
Waarden (gescheiden met | of alternatief): main
Gebruik * om alle waarden op te geven.
rvlimit
Limit how many revisions will be returned.
May only be used with a single page (mode #2).
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
rvexpandtemplates
Verouderd.
Use action=expandtemplates instead. Expand templates in revision content (requires rvprop=content).
Type: boolean (details)
rvgeneratexml
Verouderd.
Use action=expandtemplates or action=parse instead. Generate XML parse tree for revision content (requires rvprop=content).
rvparse
Verouderd.
Use action=parse instead. Parse revision content (requires rvprop=content). For performance reasons, if this option is used, rvlimit is enforced to 1.
rvsection
Only retrieve the content of this section number.
rvdiffto
Verouderd.
Use action=compare instead. Revision ID to diff each revision to. Use prev, next and cur for the previous, next and current revision respectively.
rvdifftotext
Verouderd.
Use action=compare instead. Text to diff each revision to. Only diffs a limited number of revisions. Overrides rvdiffto. If rvsection is set, only that section will be diffed against this text.
rvdifftotextpst
Verouderd.
Gebruik in plaats hiervan action=compare. Een "pre-save"-transformatie uitvoeren op de tekst alvorens de verschillen te bepalen. Alleen geldig indien gebruikt met rvdifftotext.
rvcontentformat
Verouderd.
Serialization format used for rvdifftotext and expected for output of content.
Een van de volgende waarden: text/x-wiki, text/javascript, application/json, text/css, text/plain
rvstartid
Start enumeration from this revision's timestamp. The revision must exist, but need not belong to this page.
Type: geheel getal
rvendid
Stop enumeration at this revision's timestamp. The revision must exist, but need not belong to this page.
Type: geheel getal
rvstart
From which revision timestamp to start enumeration.
Type: timestamp (allowed formats)
rvend
Enumerate up to this timestamp.
rvdir
In which direction to enumerate:
newer
List oldest first. Note: rvstart has to be before rvend.
older
List newest first (default). Note: rvstart has to be later than rvend.
Een van de volgende waarden: newer, older
Standaard: older
rvuser
Only include revisions made by user.
Type: gebruikersnaam
rvexcludeuser
Exclude revisions made by user.
rvtag
Alleen revisies met dit label weergeven.
rvtoken
Verouderd.
Which tokens to obtain for each revision.
Waarden (gescheiden met | of alternatief): rollback
rvcontinue
When more results are available, use this to continue.
