MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=imageusage (iu)
(main | query | imageusage)
  • Voor deze module zijn leesrechten nodig.
  • This module can be used as a generator.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Find all pages that use the given image title.
Parameters:
iutitle
Title to search. Cannot be used together with iupageid.
iupageid
Page ID to search. Cannot be used together with iutitle.
Type: geheel getal
iucontinue
When more results are available, use this to continue.
iunamespace
De door te lopen naamruimte.
Waarden (gescheiden met | of alternatief): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
Gebruik * om alle waarden op te geven.
iudir
The direction in which to list.
Een van de volgende waarden: ascending, descending
Standaard: ascending
iufilterredir
How to filter for redirects. If set to nonredirects when iuredirect is enabled, this is only applied to the second level.
Een van de volgende waarden: all, redirects, nonredirects
Standaard: all
iulimit
How many total pages to return. If iuredirect is enabled, the limit applies to each level separately (which means up to 2 * iulimit results may be returned).
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
Standaard: 10
iuredirect
If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved.
Type: boolean (details)
