MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
prop=imageinfo (ii)
(main | query | imageinfo)
  • Voor deze module zijn leesrechten nodig.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Returns file information and upload history.
Parameters:
iiprop
Which file information to get:
timestamp
Adds timestamp for the uploaded version.
user
Adds the user who uploaded each file version.
userid
Add the ID of the user that uploaded each file version.
comment
Comment on the version.
parsedcomment
Parse the comment on the version.
canonicaltitle
Adds the canonical title of the file.
url
Gives URL to the file and the description page.
size
Adds the size of the file in bytes and the height, width and page count (if applicable).
dimensions
Alias for size.
sha1
Adds SHA-1 hash for the file.
mime
Adds MIME type of the file.
thumbmime
Adds MIME type of the image thumbnail (requires url and param iiurlwidth).
mediatype
Voegt het mediatype van het bestand toe.
metadata
Lists Exif metadata for the version of the file.
commonmetadata
Lists file format generic metadata for the version of the file.
extmetadata
Lists formatted metadata combined from multiple sources. Results are HTML formatted.
archivename
Adds the filename of the archive version for non-latest versions.
bitdepth
Adds the bit depth of the version.
uploadwarning
Used by the Special:Upload page to get information about an existing file. Not intended for use outside MediaWiki core.
badfile
Adds whether the file is on the MediaWiki:Bad image list
Waarden (gescheiden met | of alternatief): timestamp, user, userid, comment, parsedcomment, canonicaltitle, url, size, dimensions, sha1, mime, thumbmime, mediatype, metadata, commonmetadata, extmetadata, archivename, bitdepth, uploadwarning, badfile
Standaard: timestamp|user
iilimit
How many file revisions to return per file.
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
Standaard: 1
iistart
Timestamp to start listing from.
Type: timestamp (allowed formats)
iiend
Timestamp to stop listing at.
iiurlwidth
If iiprop=url is set, a URL to an image scaled to this width will be returned. For performance reasons if this option is used, no more than 50 scaled images will be returned.
Type: geheel getal
Standaard: -1
iiurlheight
Similar to iiurlwidth.
Type: geheel getal
Standaard: -1
iimetadataversion
Version of metadata to use. If latest is specified, use latest version. Defaults to 1 for backwards compatibility.
Standaard: 1
iiextmetadatalanguage
What language to fetch extmetadata in. This affects both which translation to fetch, if multiple are available, as well as how things like numbers and various values are formatted.
Standaard: nl
iiextmetadatamultilang
If translations for extmetadata property are available, fetch all of them.
Type: boolean (details)
iiextmetadatafilter
If specified and non-empty, only these keys will be returned for iiprop=extmetadata.
Separate values with | or alternative. Het maximaal aantal waarden is 50 (500 voor bots).
iiurlparam
A handler specific parameter string. For example, PDFs might use page15-100px. iiurlwidth must be used and be consistent with iiurlparam.
Default: (empty)
iibadfilecontexttitle
If badfilecontexttitleprop=badfile is set, this is the page title used when evaluating the MediaWiki:Bad image list
iicontinue
When more results are available, use this to continue.
iilocalonly
Look only for files in the local repository.
