MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=allrevisions (arv)
(main | query | allrevisions)
  • Voor deze module zijn leesrechten nodig.
  • This module can be used as a generator.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
Toon alle versies.
Parameters:
arvprop
Which properties to get for each revision:
ids
The ID of the revision.
flags
Revision flags (minor).
timestamp
The timestamp of the revision.
user
User that made the revision.
userid
User ID of the revision creator.
size
Length (bytes) of the revision.
slotsize
Length (bytes) of each revision slot.
sha1
SHA-1 (base 16) of the revision.
slotsha1
SHA-1 (base 16) of each revision slot.
contentmodel
Content model ID of each revision slot.
comment
Comment by the user for the revision.
parsedcomment
Parsed comment by the user for the revision.
content
Tekst van de revisie.
tags
Labels voor de versie.
roles
List content slot roles that exist in the revision.
parsetree
Verouderd. Use action=expandtemplates or action=parse instead. The XML parse tree of revision content (requires content model wikitext).
Waarden (gescheiden met | of alternatief): ids, flags, timestamp, user, userid, size, slotsize, sha1, slotsha1, contentmodel, comment, parsedcomment, content, tags, roles, parsetree
Standaard: ids|timestamp|flags|comment|user
arvslots
Which revision slots to return data for, when slot-related properties are included in arvprops. If omitted, data from the main slot will be returned in a backwards-compatible format.
Waarden (gescheiden met | of alternatief): main
Gebruik * om alle waarden op te geven.
arvlimit
Limit how many revisions will be returned.
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
arvexpandtemplates
Verouderd.
Use action=expandtemplates instead. Expand templates in revision content (requires arvprop=content).
Type: boolean (details)
arvgeneratexml
Verouderd.
Use action=expandtemplates or action=parse instead. Generate XML parse tree for revision content (requires arvprop=content).
arvparse
Verouderd.
Use action=parse instead. Parse revision content (requires arvprop=content). For performance reasons, if this option is used, arvlimit is enforced to 1.
arvsection
Only retrieve the content of this section number.
arvdiffto
Verouderd.
Use action=compare instead. Revision ID to diff each revision to. Use prev, next and cur for the previous, next and current revision respectively.
arvdifftotext
Verouderd.
Use action=compare instead. Text to diff each revision to. Only diffs a limited number of revisions. Overrides arvdiffto. If arvsection is set, only that section will be diffed against this text.
arvdifftotextpst
Verouderd.
Gebruik in plaats hiervan action=compare. Een "pre-save"-transformatie uitvoeren op de tekst alvorens de verschillen te bepalen. Alleen geldig indien gebruikt met arvdifftotext.
arvcontentformat
Verouderd.
Serialization format used for arvdifftotext and expected for output of content.
Een van de volgende waarden: text/x-wiki, text/javascript, application/json, text/css, text/plain
arvuser
Only list revisions by this user.
Type: gebruikersnaam
arvnamespace
Alleen pagina's in deze naamruimte weergeven.
Waarden (gescheiden met | of alternatief): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
arvstart
The timestamp to start enumerating from.
Type: timestamp (allowed formats)
arvend
The timestamp to stop enumerating at.
arvdir
In which direction to enumerate:
newer
List oldest first. Note: arvstart has to be before arvend.
older
List newest first (default). Note: arvstart has to be later than arvend.
Een van de volgende waarden: newer, older
Standaard: older
arvexcludeuser
Don't list revisions by this user.
arvcontinue
When more results are available, use this to continue.
arvgeneratetitles
When being used as a generator, generate titles rather than revision IDs.
Voorbeelden:
Toon de laatste 50 bijdragen van gebruiker Example.
api.php?action=query&list=allrevisions&arvuser=Example&arvlimit=50 [open in de zandbak]
List the first 50 revisions in the main namespace.
api.php?action=query&list=allrevisions&arvdir=newer&arvlimit=50 [open in de zandbak]
