MediaWiki API hulp
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/API
list=alldeletedrevisions (adr)
(main | query | alldeletedrevisions)
  • Voor deze module zijn leesrechten nodig.
  • This module can be used as a generator.
  • Bron: MediaWiki
  • Licentie: GPL-2.0-or-later
List all deleted revisions by a user or in a namespace.
Parameters:
adrprop
Which properties to get for each revision:
ids
The ID of the revision.
flags
Revision flags (minor).
timestamp
The timestamp of the revision.
user
User that made the revision.
userid
User ID of the revision creator.
size
Length (bytes) of the revision.
slotsize
Length (bytes) of each revision slot.
sha1
SHA-1 (base 16) of the revision.
slotsha1
SHA-1 (base 16) of each revision slot.
contentmodel
Content model ID of each revision slot.
comment
Comment by the user for the revision.
parsedcomment
Parsed comment by the user for the revision.
content
Tekst van de revisie.
tags
Labels voor de versie.
roles
List content slot roles that exist in the revision.
parsetree
Verouderd. Use action=expandtemplates or action=parse instead. The XML parse tree of revision content (requires content model wikitext).
Waarden (gescheiden met | of alternatief): ids, flags, timestamp, user, userid, size, slotsize, sha1, slotsha1, contentmodel, comment, parsedcomment, content, tags, roles, parsetree
Standaard: ids|timestamp|flags|comment|user
adrslots
Which revision slots to return data for, when slot-related properties are included in adrprops. If omitted, data from the main slot will be returned in a backwards-compatible format.
Waarden (gescheiden met | of alternatief): main
Gebruik * om alle waarden op te geven.
adrlimit
Limit how many revisions will be returned.
Niet meer dan 500 (5.000 voor bots) toegestaan.
Type: geheel getal of max
adrexpandtemplates
Verouderd.
Use action=expandtemplates instead. Expand templates in revision content (requires adrprop=content).
Type: boolean (details)
adrgeneratexml
Verouderd.
Use action=expandtemplates or action=parse instead. Generate XML parse tree for revision content (requires adrprop=content).
adrparse
Verouderd.
Use action=parse instead. Parse revision content (requires adrprop=content). For performance reasons, if this option is used, adrlimit is enforced to 1.
adrsection
Only retrieve the content of this section number.
adrdiffto
Verouderd.
Use action=compare instead. Revision ID to diff each revision to. Use prev, next and cur for the previous, next and current revision respectively.
adrdifftotext
Verouderd.
Use action=compare instead. Text to diff each revision to. Only diffs a limited number of revisions. Overrides adrdiffto. If adrsection is set, only that section will be diffed against this text.
adrdifftotextpst
Verouderd.
Gebruik in plaats hiervan action=compare. Een "pre-save"-transformatie uitvoeren op de tekst alvorens de verschillen te bepalen. Alleen geldig indien gebruikt met adrdifftotext.
adrcontentformat
Verouderd.
Serialization format used for adrdifftotext and expected for output of content.
Een van de volgende waarden: text/x-wiki, text/javascript, application/json, text/css, text/plain
adruser
Only list revisions by this user.
Type: gebruikersnaam
adrnamespace
Alleen pagina's in deze naamruimte weergeven.
Waarden (gescheiden met | of alternatief): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15
adrstart
The timestamp to start enumerating from.
May only be used with adruser.
Type: timestamp (allowed formats)
adrend
The timestamp to stop enumerating at.
adrdir
In which direction to enumerate:
newer
List oldest first. Note: adrstart has to be before adrend.
older
List newest first (default). Note: adrstart has to be later than adrend.
Een van de volgende waarden: newer, older
Standaard: older
adrfrom
Start listing at this title.
Cannot be used with adruser.
adrto
Stop listing at this title.
adrprefix
Search for all page titles that begin with this value.
adrexcludeuser
Geen revisies door deze gebruiker weergeven.
adrtag
Alleen versies met dit label weergeven.
adrcontinue
When more results are available, use this to continue.
adrgeneratetitles
When being used as a generator, generate titles rather than revision IDs.
Voorbeelden:
Toon de laatste 50 verwijderde bijdragen van gebruiker Example.
api.php?action=query&list=alldeletedrevisions&adruser=Example&adrlimit=50 [open in de zandbak]
Toon de eerse 50 verwijderde versies in de hoofdnaamruimte.
api.php?action=query&list=alldeletedrevisions&adrdir=newer&adrnamespace=0&adrlimit=50 [open in de zandbak]
